14 years agoQsys pcie ref design - read and write descriptors
I'm using the Qsys Pcie to DDR3 reference design that's available on the altera website. With that I'm using a jungo driver and the pcie simple sw example that's posted on the alterawiki. The refer...
14 years agoI have not yet tried it but...
1. Has anyone modified the mSGDMA to distinguish between a read and a write descriptor? >> it is possible to have set of mSGDMA for each dedicated direction. >> just make 3 components for each directions, read master, write master, and dispatcher 2. Should I just rename DMA_write to DMA_read (and vice versa) in the software program and ditch the slavewrite and slave reads that seem to be transferring expected data? >> as noted above, you need to have 2 sets. 3. If I'm using the DMA read function, should I just set the write address to an unused memory space on the DDR3? >> as far as I know, the DDR3 does not accept 2 access at a time. >> it means, only read or write operation can be done at a time. >> if write happens after the read, any address should be fine.
