14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
13 years ago --- Quote Start --- I'll have to re-run these tests in 12.1 and see if anything has changed. --- Quote End --- If anything has changed in 12.1?
