14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
13 years agoSo far I haven't had a problem negotiating at x4 gen2. My design is a custom PCB with different clock sources to the dev board. The reconfig_pll is driven by an external free running clock at 125Mhz on LVDS pins. Also the design passes timing - perhaps this was cleaned up in QuartusII v12. I'm not in a position to measure the reconfiguration time as no chipscope support for my cable.
Chris
