14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
13 years agoHi Chris,
--- Quote Start --- Did you contact Altera about 'reconfiguration busy' being asserted for ~6ms? Did anyone confirm your timing on another part? --- Quote End --- I didn't contact Altera about this aspect (my discussions with them were regarding the failure to meet timing). I don't recall if I tested this on multiple parts. --- Quote Start --- Did you determine if a longer reset period before allowing altgx_reconfig to start improves link negotiation for 4x ? --- Quote End --- I didn't try. Have you? --- Quote Start --- Was this support entry posted thanks to your design? www altera com/support/kdb/solutions/rd12172009_309.html --- Quote End --- I don't think so. I do recall seeing recommendations like this, though many of the example designs neglect to implement it. Cheers, Dave
