14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
13 years agoHi Dave,
Did you contact Altera about 'reconfiguration busy' being asserted for ~6ms? Did anyone confirm your timing on another part? Did you determine if a longer reset period before allowing altgx_reconfig to start improves link negotiation for 4x ? Was this support entry posted thanks to your design? www altera com/support/kdb/solutions/rd12172009_309.html Chris
