14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
14 years agoMy update on this....
As well as not meeting timing I had a problem with an Error 10232 when I tried building a Quartus 11.0 Qsys system in Quartus 11.1sp2. The solution to this was to move a PIO output in the Qsys memory map, this not only cleared the error but from that point on all my designs have been meeting timing. :confused: Nial
