14 years agoQsys PCIe core fails timing
Hi, I've been analyzing the Altera PCIe Hard-IP cores. I started off with the Qsys PCIe code, since it had the simplest interface. Here's the test setup: * Quartus 11.0, 11.1sp1, 11.1...
14 years agoThanks for your examples and instructions! This is very useful for understanding of Altera's tools.
One more bit of information to consider: we use Altera's dev. board with Stratix IV and used their PCIe+DDR3 example as a starting point. It turns out that when their example is synthesized and P&R'ed, it does not meet timing and the README file says to ignore it! And it actually works on the board! So, the question is if Altera tools say that timing requirements are not met, does it really mean the timing requirements are not met? Conversely, if Altera tools say that timing requirements are met, does it really mean the timing requirements are met? Not a lot of confidence.
