rled64
1 year agoQSYS amm interconnect delay with EMIF (Arria 10)
Hello community, Using Terasic HAN Pilot Plateform (Arria 10), I recently found interesting behavior when using qsys or not for read/write operations to DDR4 external memory through EMIF. Basical...
AdzimZM_Altera
1 year agoHi
Do you still have any timing issue after you remove the Signal Tap?
Adzim
- rled641 year ago
Hi Adzim,
Sorry for late response, in fact I could resolve the timing issue while keeping signaltap, this was due to the trigger clock which was set to "DDR4A_REF_CLK" (reference clock input for EMIF) instead of the emif_usr_clk of EMIF. Since these have both the same frequency, I have troubles understanding why using the dedicated ref clk in signaltap generated timing errors ? If you have any insight about this, you're welcome.
I will close the topic after this, thanks again for help !
