QSYS amm interconnect delay with EMIF (Arria 10)
I found that the waitrequest every 2080 cycle is related with the refresh interval "tREFI" of 7,8 µs which exactly corresponds with 2080 cycles at 266 MHz. So I believe everything works well, I just have to take this into account for estimating maximum DDR datarate which is about 65Gbps instead of 68Gbps, which is fine.
For Timing errors, I don't have any setup error, but I have 4 hold errors for instance with this path :
-0.346 u0|emif_0|emif_0|arch|arch_inst|io_tiles_wrap_inst|io_tiles_inst|tile_gen[0].tile_ctrl_inst|pa_core_clk_out[0] auto_fab_0|alt_sld_fab_0|alt_sld_fab_0|auto_signaltap_auto_signaltap_0|sld_signaltap_inst|acq_data_in_reg[102] u0|emif_0|emif_0_core_usr_clk u0|emif_0|emif_0_core_usr_clk 0.000 3.609 3.688 Slow 900mV 0C Model
Also I have 1 single timing error in the "Report DDR" of the timing analyser, for all 4 models (slow/fast/0C/100C), which is on the "Read Capture" signal of EMIF :
Actually the design works but I don't know what to do with these errors, do you believe it is relevant to fix them ? Maybe this is only due to signaltap logic.
Yes, remove Signal Tap and see if you are still having timing issues.
