CChan217
6 years agoprogramming return errors without SmartVID PMBus connection to S10
I have a board populated with Stratix 10 1SG085HN3F43E1VG
Device programming return errors. We found out that we have SmartVID device and a Fixed Voltage Power Supply without PMbus conection to S10.
Is any chance to run SmartVID device on this board?
- Rahul_S_Intel1
Is it possible for you to contact Distributor or file IPS case. For further support.
- CChan217
Hi! I don't have the Intel Premier support Yet. And I have a programming issue to program the Stratix 10 using JTAG and the AVST x16. I am not sure that is the smartVID PMBus connection to cause the problem.
- Rahul_S_Intel1
May I know what is the error message that you are getting.
- CChan217
Hi! RSree Below is the error messge we get using the JTAG to program the stratix 10 During downloading .sof to the FPGA through this blaster , there is an error message : at the 1st time after power up : Info (19848) : Regular SEU info => 53 sector(s), 4 thread(s), 31500 interval time in microsecond(s) Info (19848) : Design hash is 2F4FC0AF133B89A9FFF906CAF0085E3600000000000000000000000000000000 Info (209060) : Started Programmer operation at Tue Oct 15 10:59:42 2019 Info (18942) : Configuring device index 1 Error (18950) : Device has stopped receiving configuration data Error (18948) : Error message received from device: Device is in configuration state. Error (209012) : Operation failed Info (209061) : Ended Programmer operation at Tue Oct 15 11:00:01 2019 without power down , we start again , this time the message is slightly different : Info (19848) : Regular SEU info => 53 sector(s), 4 thread(s), 31500 interval time in microsecond(s) Info (19848) : Design hash is 2F4FC0AF133B89A9FFF906CAF0085E3600000000000000000000000000000000 Info (209060) : Started Programmer operation at Tue Oct 15 10:56:58 2019 Info (18942) : Configuring device index 1 Error (18952) : Error status: Device does not accept configuration request Error (209012) : Operation failed Info (209061) : Ended Programmer operation at Tue Oct 15 10:57:06 2019 I also found the article the people has a problem to program the S10 without the PMbus to S10. So that why I doubt about the PMbus connection to S10. Regards Colin- CChan217
Hi! Rsree
Do you have solution to skip the PMbus SmartVID control from the FPGA?
Colin
