11 years agoProblems with PCI express IP Compiler and Pin Planner
Hi, I began to study PCI Express system in order to implement on a FPGA. I'm using Stratix II GX development Kit board and i already am at the point to connect the pins of the FPGA using the Pin Planner Editor. The problem is that i don't know how to relate the signals in the top level generated by de PCI Express Ip Compiler and the correct pins on the FPGA. I really appreciate if anybody can give me a correct assignment file. The target FPGA is the EP2SGX90FF1508C3. Thank you very much in advance
1 Reply
First, you need refer to Figure 5–41 of IP Compiler for PCIe User Guide to understand the PCIe Rx/Tx transceiver channels location assignments.
The assignment is like this: Transceiver Ch0 --> PCIe Rx0/TX0 Transceiver Ch1 --> PCIe Rx1/TX1 Transceiver Ch2 --> PCIe Rx2/TX2 Transceiver Ch3 --> PCIe Rx3/TX3 ... and so on The refer to the Stratix II device pin-out files to know the pin location assignment.
