11 years agoProblems with PCI express IP Compiler and Pin Planner
Hi, I began to study PCI Express system in order to implement on a FPGA. I'm using Stratix II GX development Kit board and i already am at the point to connect the pins of the FPGA using the Pin Plan...
11 years agoFirst, you need refer to Figure 5–41 of IP Compiler for PCIe User Guide to understand the PCIe Rx/Tx transceiver channels location assignments.
The assignment is like this: Transceiver Ch0 --> PCIe Rx0/TX0 Transceiver Ch1 --> PCIe Rx1/TX1 Transceiver Ch2 --> PCIe Rx2/TX2 Transceiver Ch3 --> PCIe Rx3/TX3 ... and so on The refer to the Stratix II device pin-out files to know the pin location assignment.
