14 years agoProblems with FFT Megacore of Variable Streaming Floating Point Architecture
I've already used with success FFT Megacore of Variable Streaming Fixed Point architecture. Now I'm trying to use Floating Point architecture and it seems to me that the Core is not responding proper...
14 years agoI just tried to lower the clock frequency to 25 MHz, but it gives me back the same response. QSYS tells me I cannot lower it anymore since the debug module I'm using works at clocks faster then 20 MHz.
Maybe some other informations could be useful for you to help me: I've set my FFT core for a maximum length of 1024 and for input and output sequences in natural order. I'm using a couple of SG-DMA in my QSYS system for writing to and reading from Avalon Streaming interface: for both SGDMA cores, data width is 64 bits (to accomodate real and imag 32-bits wide FFT data) and I've enabled automatic byte swap (bursting and unaligned transfers are disabled instead).
