16 years agoProblem With Quartus 2 And Hi-z
i have an entity with 38 bidirectional lines (IO). I have a process that initialize a temporary signal (st_logic-vector) to Z (so i have 38 Z): IOtemp<=ZZZZZZZ...; When a control signal goes to '1' this temporary signal is filled with 1 or 0 in precise positions (so i have this 38 lines signal with some 0, some 1 and others line with Z). eg; IOtemp<=ZZ1Z01Z......; After filling the IOtemp signal, this IOtemp signal is copied to bidirectional lines: IO<=IOtemp; but if i simulate the .vho file from quartus in my ActiveHDL project the line that must be Z (high impedance) are 0 or 1 and the others lines are correct. All signal are std_logic_vector Why? Please help me. Thanks Nick1 Reply
do you have a test case code i can synthesize?
