Problem with CXL IP Design Example Type 3 on DK-DEV-AGI027RBES
- 2 years ago
Hi again,
The problem was on the PCIe slot on the server side.
We replaced our card and the problem was fixed.
For anyone facing the same problems, we had to check the x16 slot with other devices to identify the lane drop issue in BIOS.
CXL IP designs apparently are note recognized in BIOS as PCIe devices even when the design is working -- the corresponding PCIe slot always shows the message "Link did not train" -- as if nothing is attached on the slot.
Thank you for your help,
Chloe
Thank you for your reply -- We are trying to figure out if it is a server problem as you pointed out.
Our server is CXL compatible but we may face a PCIe drop lane issue.
As a clarification the CXL IP cannot tolerate 8 lanes on the PCIe slot, right?
I will keep you posted once we have figured out.
Best,
Chloe
Hi again,
Chloe
