xalverti
2 years agoProblem with CXL IP Design Example Type 3 on DK-DEV-AGI027RBES
Hi, We are using Quartus 24.1 to compile the type 3 ddr memory design example for the board and program the FPGA using the following guide: Agilex™ 7 R-Tile Compute Express Link* (CXL*) FPGA IP Des...
- 2 years ago
Hi again,
The problem was on the PCIe slot on the server side.
We replaced our card and the problem was fixed.
For anyone facing the same problems, we had to check the x16 slot with other devices to identify the lane drop issue in BIOS.
CXL IP designs apparently are note recognized in BIOS as PCIe devices even when the design is working -- the corresponding PCIe slot always shows the message "Link did not train" -- as if nothing is attached on the slot.
Thank you for your help,
Chloe
WZ2
2 years agoHi there,
I need to confirm a few pieces of information with you:
- What was the cause of the previous issue with the PMBUS on the board?
- Have you tried the PCIe Gen5 example design and did it train successfully (because PCIe is more general)?
WZ
