Problem with CXL IP Design Example Type 3 on DK-DEV-AGI027RBES
- 2 years ago
Hi again,
The problem was on the PCIe slot on the server side.
We replaced our card and the problem was fixed.
For anyone facing the same problems, we had to check the x16 slot with other devices to identify the lane drop issue in BIOS.
CXL IP designs apparently are note recognized in BIOS as PCIe devices even when the design is working -- the corresponding PCIe slot always shows the message "Link did not train" -- as if nothing is attached on the slot.
Thank you for your help,
Chloe
Hi there,
I check the setting in quartus is no error, please set all switch to their default setting(just like User guire )
https://www.intel.com/content/www/us/en/docs/programmable/683288/current/default-settings.html
SW4 should be all off, it can enable sdm_pmbus signal and communicate with Voltage regulator.
WZ
