Problem in download bitstream on Stratix 10 MX board
Hi John,
Thanks for the reply.
I was able to solve the issue by assigning the correct pin numbers to reference clocks of HBM.
I was able to build the Qsys design with MCDMA IP interfaced with HBM Controller through AXI bridge. ( I have modified the example design PCIe + DDR + HBM2. I have replaced PCIe endpoint IP with MCDMA IP).
https://fpgacloud.intel.com/devstore/platform/19.1.0/Pro/an881-pcie-avmm-dma-gen3x16-ddr4-and-hbm2/
I am able to build and program the design successfully using Quartus 21.3 version.
During software test, system is not able to work with burstcount greater than 1. I have enabled burstcount greater than 1 option during HBM Controller generation. I have given it as 128 (max is 256).
Does HBM controller with AXI interface works with burst count greater than 1 ?
Pramod
