14 years agoProblem in controlling FFT megacore function???
Hi, I'm currently working in a project, in which I use FFT block to correlate signal. I got stuck in simulating the fft block. My block do fft for 1024 points. I use a clock 1Mhz to clock. I simu...
14 years ago --- Quote Start --- It's fine to not use clk enable so long as you didn't select it as an option when you created the function. I'm not sure I understand your SOP and EOP question, how are you trying to generate it from one source? The SOP and EOP need to indicate the packet size to the FFT engine. I haven't tested it myself, but if you set the distance between the two to longer than the packet length, I imagine it's going to continually overwrite the final value until the EOP signal is received. --- Quote End --- Thank's @el07dm
