14 years agoProblem in controlling FFT megacore function???
Hi, I'm currently working in a project, in which I use FFT block to correlate signal. I got stuck in simulating the fft block. My block do fft for 1024 points. I use a clock 1Mhz to clock. I simu...
14 years agoThis could be a couple of things.
Have you asserted source_ready? Have you included a global clock enable, which will also need to be asserted? What are you using for your input?
