14 years agoPLL IP Core
I'm interesting to use clock dividing/multiplication. Use the IP MegaWizard ALTPLL. As i have seen in datasheet, before the MegaWizard function will start work, the asynchronous reset (areset input) have to be done. The Quartus compilation the code was passed, but during ModelSim simulation i got the negative result. The simulation started but automatically stoped (fatal error) the same place where the asynchronous reset for MegaWizard Core was ended. The fatal error message is "floating point exception". I tried to convert: 50Mhz to 10mhz; 50Mhz to 100Mhz; The asynchronous reset I'm making by the counter. what is the reason for the error? Thanks.
