14 years agoPLL IP Core
Hi, I'm interesting to use clock dividing/multiplication. Use the IP MegaWizard ALTPLL. As i have seen in datasheet, before the MegaWizard function will start work, the asynchronous reset (areset ...
14 years agosorry,it was 10MHz.
I have tried to simulate without reset, it's running without any error. But output freq is 'X' value logic...as i said bafore i think it's happens because the ALTPLL modul not locked on my incoming freq... I don't know why... I used the default values of the modul, only the incoming and outcoming freqs were changed.
