10 years ago
PLL does not lock anymore after connecting DDR3
Hi
I'm designing a system with an NIOS and a DDR3 HMI.
The fist shot was to implement the NIOS with internal RAM and a PLL. The PLL generates 50MHz from my connected 25MHz crystal. This setup works fine, and the Hello World from NIOS works as well.
Now I would like to have the DDR3 SDRAM running. But since I intergated the DDR3, my PLL doesn't lock anymore!!
The refclock for the DDR3 is directly from the 25MHz crystal and i can see the 355MHz AFI is coming out (with a scope).
I tried to connect the PLL for the Nios to
-directly the same 25MHz-Pin as the DDR3
-At the AFI 355MHz output
But the PLL does not lock! Not at 50MHz or at 71MHz which would be 355/5
Thanks for any advice
    Are you able to simulate your design to see if same issue there?
    Well the problem was that the RREF pin. After connecting it correctly it worked:
    Cyclone® V Device Family Pin Connection Guidelines:
    If any PLL, REFCLK pin, or transceiver channel is used, you must connect each RREF pin on that
    side of the device through its own individual 2.0-kΩ +/- 1% resistor to GND. Otherwise, you may
    connect each RREF pin on that side of the device directly to GND. In the PCB layout, the trace
    from this pin to the resistor needs to be routed so that it avoids any aggressor signals.
    Glad to hear that you have managed to resolve the issue. Thanks for sharing the solution as well.
