Lorne_K_Intel
6 years agoPlatform Designer HDL generation errors on AN 830: Intel FPGA Triple-Speed Ethernet and On-Board PHY
platform designer qsys_top.qsys generate HDL exited with errors
https://fpgacloud.intel.com/devstore/platform/19.3.0/Pro/an-830-intel-fpga-triple-speed-ethernet-and-on-board-phy-chip-reference-desi...
- 6 years ago
I found a workaround of this problem, please unzip the attached file to get the two missing folders (crc32 & User_Logic), and then locate it at "platform" folder. After that, you should be able to generate the platform designer of this example.
Regards -SK
SengKok_L_Intel
6 years agoIf further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
