Platform Designer fails QDR II elaboration revisited
I found the following solution, maybe you can try and check if the issue solved:
https://www.intel.com/content/www/us/en/support/programmable/articles/000086438.html
- K_Crocker2 years ago
Thank you for your reply!!
I checked my WSL installation and found that only "amd64" was active. I added "i386" and re-ran the instructions on the following page:
https://www.intel.com/content/www/us/en/support/programmable/articles/000074066.html
I rebooted my machine and attempted to generate my QSys again, which failed with the same error.
Here's another data point, though: I just acquired a new Windows 11 Pro machine, so yesterday I installed 23.1std, WSL 1, Ubuntu 18.04 LTS and followed all the "sudo update" instructions. I attempted a QSys generation and it succeeded! I didn't install Eclipse yet, so we'll see if everything holds. If so, that may be the end of it. I'll post again when I know more.
