13 years ago
Phase alignment reference using ALTPLL and ALTPLL_RECONFIG modules
My system contains a PLL linked to a PLL Reconfig module driven by a microcontroller via the Avalon-MM port.
I used the AN661 PDF (altera.com/literature/an/an661.pdf Page 4 and 5) to understand the PLL Reconfig module interface and program it.
I obtain the desired frequencies but I don’t manage to obtain a zero degree phase.
The Phase related register at address 000110 is a write only reg and permits to shift the phase from the current value of the phase, am I right ?
How can I know the current phase ? How can I align my outputs clocks to the VCO or the input clock ?
I just want to align the low to high edge of my two output clocks (c1 = c0 / 8).
Thanks for your help,
Romain.
1 Reply
    First, a correction : for ArriaV family it's not ALTPLL any more, but ALTERA_PLL IP.
    Then in the ALTERA_PLL User Guide, it is explained that the pin reset, just reset counters and locked state, not the whole PLL and its config.
    So now, I apply the reconfig, then I reset PLL, and the clocks are all aligned.
