PFL IP core causing Flash access error
- 5 years ago
To reach the solution, I tried following solutions
1) Init_done signal from FPGA is feedback to one of the FPGA's input pin and enable all the FPGA logics AFTER "Init_done" is high.
2) Reset the Flash device after Init_done is high and before writing data to Flash.
3) Use "Flash_ready" signal to verify the Flash state after reset.
I hope this helps.
If there is no further information needed, I will proceed to close this case.
Aiman
I hope this helps.
