Knug
Contributor
5 years agoPFL - Flash queries
Wrt Parallel Flash Loader Intel FPGA IP User Guide pg17 :
Can someone please explain the following wrt
"Page Start Address, End Address, and Page-Valid Bit Stored as Option Bits" Fig12 diagram ...
YuanLi_S_Intel
5 years agoHi,
Yes, you are right. If you convert from POF to RBF using Quartus Convert Programming File. You cannot configure the FPGA using PFL IP.
Thus, you need to use the command as suggested by Shafieq. Please work with Shafieq for NIOS II related command. He is the domain of expert.
Thank You.
