Periodic Pulses Pattern
I'm a new Verilog programmer and still rely on examples to write code.
I didn't find any example of what I need.
I need to generate two pulses periodicaly like this following schema:
clk is the base of the period (pulse every 8 ticks for example).
pulse1: rises 3 ticks after positive edge of clk and falls 2 ticks later.
pulse2: rises 4 ticks after positive edge of clk and falls 3 ticks later.
I'd like also generates the pulses for a limited number (N) of periods, 1 ≤ N < ∞.
I suppose I have to use temporisation conditions (#t) but didn't success to synchronize them to posedge of clk.
Thank for your help.
- Nurina
Thank you for using Intel Communities.
Please allow some time while I investigate.
Nurina
- Nurina
Are you trying to do this for simulation only? Are you trying to have a testbench to show this behaviour?
Can you share what you currently have?
Nurina
- AnonymousNot applicable
Thank you to your answer,
Yes it is for a testbench only. I have no result because I didn't find how writing the code to obtain the desired result.
Best regards.
Daniel
- Nurina
Can you attach the code you have written so we can work from there?
Nurina
- AnonymousNot applicableHere are the expected periodicaly outputs of the test bench:I tried this code. What is the problem?`timescale 1us/1nsmodule Pulses(clk, pulse1, pulse2);output clk, pulse1, pulse2;wire c, p1, p2;initialbeginc = 0;p1 = 0;p2 = 0;repeat(1000) //1000 cycles repeatedbegin#0 c = 1;#1 c = 0;#2 p1 = 1;#1 p2 = 1;#1 p1 = 0;#2 p2 = 0;#1 ;endassign clk = c;assign pulse1 = p1;assign pulse2 = p2;endendmodule
Thank you
- Nurina
That doesn't look like a testbench. How are you simulating this? Are you using ModelSim/QuestaSim?
I tried using QuestaSim and managed to get the output you want.
First of all, a testbench shouldn't have any ports declaration -> module Pulses(clk, pulse1, pulse2);
It should be empty like so -> module Pulses ();
And I don't think you can use assign in testbench.
Please refer to the verilog files I'm attaching. periodic_pulses.v is the top verilog file in your Quartus project and periodic_pulses_tb.v is the testbench.
Follow the steps here to compile and run simulation, it should be the same for Quartus Lite:
QuestaSim: https://www.intel.com/content/www/us/en/docs/programmable/703090/21-1/simulation-quick-start.html
ModelSim: https://www.intel.com/content/www/us/en/docs/programmable/683248/18-0/simulation-quick-start.html
Nurina
p/s: If any answer from the Intel Support is helpful, please feel free to provide rating with 4/5 survey on the support provided.
- FvM
apart from the point that outputs have no purpose in a testbench, the problem in your original code are of different kind.Assignment must take place outside the initial statement.
`timescale 1us/1ns
output reg clk, pulse1, pulse2;
reg c, p1, p2;
initial
begin
c = 0;
p1 = 0;
p2 = 0;
begin
#0 c = 1;
#1 c = 0;
#2 p1 = 1;
#1 p2 = 1;
#1 p1 = 0;
#2 p2 = 0;
#1 ;
end
endassign clk = c;
assign pulse1 = p1;
assign pulse2 = p2;
endmodule
