F-tile-ethernet-hard-ip TX/RX MAC Segmented Client Interface
"i_tx_mac_inframe" signal is explained as
" Indicates valid data in each segment for specific rate. Along with the previous segment's inframe signal, this signal indicates the SOP and EOP location." i dont understand the underlined part of explanation. how does i_tx_mac_inframe indicates start of packer (SOP) and end of packet (EOP).
can someone please elaborate on this with a couple of examples
also another question is
how to interpret i_tx_mac_data signals if i_tx_mac_valid == 1'b1 and i_tx_mac_inframe [15:0] == 16'h0 ?
- paveetirrasrie_Altera
Hello Ankit,
The i_tx_mac_inframe signal segmented client interface is a bit vector (e.g., [15:0]) that marks which segments of the i_tx_mac_data bus contain valid data in the current clock cycle. Its transitions across cycles, together with its bit pattern, allow you to identify the Start of Packet (SOP) and End of Packet (EOP) locations.
SOP, detected by a transition from all zeros to a non-zero value in i_tx_mac_inframe. The lowest set bit in i_tx_mac_inframe marks the location of the SOP in the data segments.
EOP, detected by a transition from a non-zero value to all zeros in i_tx_mac_inframe. The highest set bit in i_tx_mac_inframe marks the location of the EOP in the data segments.
For example,
SOP:
- Cycle N-1: i_tx_mac_inframe = 16'h0000
- Cycle N: i_tx_mac_inframe = 16'h00FF
- Interpretation: The change from all zeros to 16'h00FF means a new packet starts at cycle N. The lowest set bit in 16'h00FF (bit 0) marks the start of the packet in the segment.
EOP
- Cycle N+1: i_tx_mac_inframe = 16'h0000
- Interpretation: The change from 16'h00FF to all zeros means the packet ends at cycle N. The highest set bit in 16'h00FF (bit 7 if only lower byte is used) marks the end of the packet in the segment.
- If i_tx_mac_valid is asserted (1'b1), but i_tx_mac_inframe is all zeros (16'h0), this means the interface is active/ready, but there is no valid packet data in the current cycle.
- The i_tx_mac_data signals should be ignored in this cycle—they do not contain valid data.
- This can occur during inter-packet gaps or when the MAC is otherwise idle.
Hope this helps.
Pavee
Hope you're doing well,
Any updates from your end based on my previous response?
Pavee
Hello Ankit,
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get the support from Altera experts.
Thank you.
