JET60200
Contributor
5 years agoPCtoFPGA AVMM DMA data-transfer cann't complete in time randomly using A10 PCIe AVMM IP
hello experts,
we are using A10 HIP AVMM IP design as a PCIe device to pug inside X86 XEON SERVER to work with.
In Linux driver, we program FPGA AVMM DMA Engine to transfer bulk-data between...
KhaiChein_Y_Intel
5 years agoHi,
Could you provide the Signal Tap?
KhaiY
- JET602005 years ago
Contributor
Hi @KhaiChein_Y_Intel ,
1) Regarding of " Signal Tap " capture, what signal(s) do you request to capture ?
2) Also regarding of " RxErr+ ", " BadTLP+ Timeout+ ", I believe they are located in PCIe Physical Layer & Link Layer , correct ? Since they're not relatedd to PCIE Application Data, does that mean it may be a Hardware related issue ?
Thanks for feedback //
Contributor
Hello @KhaiChein_Y_Intel ,
what signals we should capture to investigate this "stuck" issue ? Is there any guidance to describre this ? Thanks in adavance
