18 years agoPCIe without Rate match FIFO
Hi, Does anybody know why a PCIe IP with rate match FIFO turned off gives the following error during compilation. It would seem to me that the IP should produce code that compiles or at least l...
18 years agoTry applying these settings in your QSF:
set_instance_assignment -name GXB_0PPM_CLOCK_GROUP 1 -to *altpcie_serdes*alt2gxb_component|channel_rec[*].receive set_instance_assignment -name GXB_0PPM_CLOCK_GROUP_DRIVER 1 -to *altpcie_serdes*alt2gxb_component|channel_quad[0].clk_div
