13 years agoPCIe simulation error: TxElecIdle not asserted
While simulating PCIe IP core using ModelSim with the testbench generated along with the IP core generation, Iam getting the following error message. ERROR: 57 ns TxElecIdle not asserted while reset asserted, Lane: 0, MAC: RP In the waveform obtained, it is found that at any time, either of three resets to the PCIe ip core (crst, npor, srst ) is active high, so that the design is not coming out of reset state and hence txelecidle0_ext is always active high and forces transmit output to electrical idle. Though I tried with another device and by changing parameters for PCIe generation, the result was same. Expecting your valuable suggestions to overcome this error. Thanks & Regards, Gibin George1 Reply
Hi Gibin,
Please try changing simulation parameters of the generated testbench. Check if you are using PIPE/serial PHY interface and set parameters accordingly. May be this will be helpful. regards, umesh
