13 years agoPCIe simulation error: TxElecIdle not asserted
Hi, While simulating PCIe IP core using ModelSim with the testbench generated along with the IP core generation, Iam getting the following error message. ERROR: 57 ns TxElecIdle not...
13 years agoHi Gibin,
Please try changing simulation parameters of the generated testbench. Check if you are using PIPE/serial PHY interface and set parameters accordingly. May be this will be helpful. regards, umesh
