13 years ago
PCIe simulation BFM differs from quartus
I've created an easy testbench for pcie. I’m trying to read and write data to different memory addresses. My design includes RAM memories(dual port alt syncram), and Input/Output PIO ports. Writing/Reading from testbench to the PIO and memories works fine, but when I compile the design it doesn't. I can read data from PCIE in my vhdl, but can't write anything. My task is called io_test. I’m using quartus sopc builder 12.1sp1 and modelsim 10.1b. Arria II Gx Device. I Can't also read anything, written by vhdl, on PCIe side from PIO port enc_out_ctrl. What can I do wrong? My testbench is based on example_pcie testbench. I only added io_test task. I communicate with Aria from linux driver. Dummy BFM master is replaced in design with my Verilog Code. I changed on_chip_ram to allow me simultenously read/write 128bits in Megawizard, it works properly in simulator tough.
 module dec_din (                  // inputs:                   address,                   address2,                   byteenable,                   byteenable2,                   chipselect,                   chipselect2,                   clk,                   clken,                   clken2,                   reset,                   write,                   write2,                   writedata,                   writedata2,                   // outputs:                   readdata,                   readdata2                ) ;    parameter INIT_FILE = "../dec_din.hex";     output   readdata;   output   readdata2;   input    address;   input    address2;   input    byteenable;   input    byteenable2;   input            chipselect;   input            chipselect2;   input            clk;   input            clken;   input            clken2;   input            reset;   input            write;   input            write2;   input    writedata;   input    writedata2;     wire     readdata;   wire     readdata2;   wire             wren;   wire             wren2;   assign wren = chipselect & write & clken;   assign wren2 = chipselect2 & write2 & clken2;   //s1, which is an e_avalon_slave   //s2, which is an e_avalon_slave      wire  sub_wire0;     wire  sub_wire1;         altsyncram    altsyncram_component (         .byteena_a (byteenable),         .clock0 (clk),         .wren_a (wren),         .address_b (address2),         .clocken0 (1'b1),         .data_b (writedata2),         .wren_b (wren2),         .address_a (address),         .data_a (writedata),         .q_a (readdata),         .q_b (readdata2),         .aclr0 (1'b0),         .aclr1 (1'b0),         .addressstall_a (1'b0),         .addressstall_b (1'b0),         .byteena_b (1'b1),         .clock1 (1'b1),         .clocken1 (1'b1),         .clocken2 (1'b1),         .clocken3 (1'b1),         .eccstatus (),         .rden_a (1'b1),         .rden_b (1'b1));     defparam         altsyncram_component.address_reg_b = "CLOCK0",         altsyncram_component.byte_size = 8,         altsyncram_component.clock_enable_input_a = "NORMAL",         altsyncram_component.clock_enable_input_b = "NORMAL",         altsyncram_component.clock_enable_output_a = "NORMAL",         altsyncram_component.clock_enable_output_b = "NORMAL",         altsyncram_component.indata_reg_b = "CLOCK0",         altsyncram_component.intended_device_family = "Arria II GX",         altsyncram_component.lpm_type = "altsyncram",         altsyncram_component.numwords_a = 128,         altsyncram_component.numwords_b = 32,         altsyncram_component.operation_mode = "BIDIR_DUAL_PORT",         altsyncram_component.outdata_aclr_a = "NONE",         altsyncram_component.outdata_aclr_b = "NONE",         altsyncram_component.outdata_reg_a = "CLOCK0",         altsyncram_component.outdata_reg_b = "CLOCK0",         altsyncram_component.power_up_uninitialized = "FALSE",         altsyncram_component.read_during_write_mode_mixed_ports = "OLD_DATA",         altsyncram_component.read_during_write_mode_port_a = "NEW_DATA_NO_NBE_READ",         altsyncram_component.read_during_write_mode_port_b = "NEW_DATA_NO_NBE_READ",         altsyncram_component.widthad_a = 7,         altsyncram_component.widthad_b = 5,         altsyncram_component.width_a = 32,         altsyncram_component.width_b = 128,         altsyncram_component.width_byteena_a = 4,         altsyncram_component.width_byteena_b = 1,         altsyncram_component.wrcontrol_wraddress_reg_b = "CLOCK0";  endmodule
