14 years agoPCIe problem with large TLPs
I'm sending a TLP (from the application layer) of 4 headers and 128 bits of data (Avalon-TX 128).
Headers look like this: header0 = 32'h60000004; //fmt = 3, length = 4 DW header1 = 32'h000000FF; //first BE = F, last BE = F header2 = 32'h00000000; header3 = address; //that is 32-bit wide Afterwars I send it like this: tx_valid_next = 1; tx_data_next = {header3, header2, header1, header0}; tx_sop_next = 1; Next cycle: sending the data tx_sop_next = 0; tx_valid_next = 1; tx_data_next = data; //that is 128-bit wide tx_eop_next = 1; Next cycle: deasserting eop and valid. Also checking TX_ready before asserting TX_valid. problem: When I use shmem_display, it shows all zeros, whereas it all works fine with the code like this: //3 DW headers, 32-bit data payload, single transaction header0 = 32'h40000001; header1 = 32'h0000000F; header2 = address; tx_valid_next = 1; tx_data_next = {data, header2, header1, header0}; tx_sop_next = 1; tx_eop_next = 1; What am I missing?2 Replies
The PCIe spec says:
--- Quote Start --- • For Addresses below 4 GB, Requesters must use the 32-bit format. --- Quote End --- So, in your TLP generator you have to check the upper 32 bits of the address to be zero and use a 3 word TLP in this case. - Altera_Forum
It worked with 3DW headers! Thanks!
