14 years agoPCIe Payload Length
Hi According to the PCIe spec, the TLP payload is 4kbytes. PCIe provided by Altera have some different types of specs which range from 128bytes to 4kbytes. I have tried to use Jungo dri...
14 years agoTo do long PCIe transfers you have to use a dma controller that is linked with the PCIe master - nothing else can actually tell the PCIe block to generate a longer TLP.
As you may have noticed PCIe isn't 'express' in any sense unless you are using long TLP.
