PCIe MSI interrupt
You may refer to Intel FPGA Wiki - Handling PCIe Interrupts
https://community.intel.com/t5/FPGA-Wiki/Handling-PCIe-Interrupts/ta-p/736044
KhaiY
- Sudhirkv5 years ago
Thanks for your reply.
Below mentioned our procedure we are following to test MSI interrupt, but we didn't get the expected output.
- Reading Config space register with offset 0x50
Offset : 0x50 Value : 25522181(decimal)
Here bit[16] set as 1 to enable MSI interrupts
2. Reading Config space register with offset 0x4
Offset : 0x4 Value : 1048582(decimal)
Here bit[10] is disable , bit[1] (Memory space) and bit[2] (Bus Master) are 1.
When link is down:-
root@localhost:~# cat /proc/interrupts | grep fpga
65: 0 0 0 0 0 0 0 0 PCI-MSI 3670016-edge fhgw_fpga_drv
When link is up:-
Please find the test log in attached file.
