FvM
3 years agoPCIe hprxm_master doesn't handle unaligned reads correctly
Hello, we have an Arria 10 PCIe design with MM DMA interface, utilizing hprxm_master (bursting BAR2 rxm) for non-DMA access. Platform designer IP does a good job translating between different clock d...
FvM
3 years agoHi,
I could reduce the test setup reproducing the error to a 32-bit Avalon MM Slave (onchip memory) connected to hprxm master. An unaligned 64-bit read crossing the 256 bit address boundary gets wrong data. I put the test into PCIe_fundamental demonstration project for TR10a-HL development kit.
onchip_memory_2_1 is the 32-bit slave, onchip_memory_2_2 a 256-bit slave that doesn't show the error.
Frank
Wincent_Altera
3 years agoHi Frank,
Thanks for sharing with me your finding.
Do you test it in Arria 10 device as well ?
Wincent_Intel
