PCIe hprxm_master doesn't handle unaligned reads correctly
You can file an IPS case via the FAE, then you can share the .qar file there for further debug.
If I understand correctly this is the design that you get from the IP catalog right ?
or this is a custom design ?
Wincent_Intel
- FvM3 years ago
I could reduce the test setup reproducing the error to a 32-bit Avalon MM Slave (onchip memory) connected to hprxm master. An unaligned 64-bit read crossing the 256 bit address boundary gets wrong data. I put the test into PCIe_fundamental demonstration project for TR10a-HL development kit.
onchip_memory_2_1 is the 32-bit slave, onchip_memory_2_2 a 256-bit slave that doesn't show the error.
Frank- Wincent_Altera3 years ago
Hi Frank,
Thanks for sharing with me your finding.
Do you test it in Arria 10 device as well ?
Wincent_Intel
