PCIe hard IP Bringup on Cyclone 10 GX custom board
We are having trouble bringing up the PCIe Hard IP on our custom board. The hard IP is set up for gen 1 x1. It appears that coreclkout is stuck low and not toggling.
Current setup:
We are using a FPGA project based on
https://fpgacloud.intel.com/devstore/platform/18.0.0/Pro/cyclone-10-gx-pcie-gen1-x1-avl-st/
The only changes we made are pin assignments for the general IO to match our custom board, and using Quartus Pro 20.4.0.
The custom board uses the Cyclone 10 GX and the hardware is set up for up to 2 lanes. The TX and RX lanes location have been verified to be correct using pin planner. They are located at bank 1C ch4 (lane0) and 5 (lane1). We also verified that the refclk is 100MHz coming from another custom board generated from a CDCM9102RHBT clock generator.
nPERST is controlled by the root complex and located at the dedicated pin (NPERSTL0) with VCCIO at 1.8, and we can see the signal goes high using signaltap
The pcie RX lane and refclk are set as CML I/O standard, and the TX lane is set at "high speed differential IO"
From our root complex, we can see that the lttsmstates changes from 0x00 > 0x01 > 0x06 > 0x01 > 0x02 > 0x03 and it stays there.
From the Cyclone 10 GX endpoint side using signaltap, the coreclockout/pld_clk, lttsmstates, and currentspeed are all stuck low.
Any suggestions on how we can go about debugging this would be greatly appreciated, or possible reasons why coreclkout is stuck low.
Thank you
- SengKok_L_Intel
This is glad to see the problem is resolved. Thanks.
Regards -SK
- SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
