PCIe hard IP Bringup on Cyclone 10 GX custom board
To identify if there is FPLL dependency, could you please change the Fpll location by using the following setting in the QSF file?
set_location_assignment FPLL_1CT -to inst|xcvr_fpll_a10_0|fpll_inst
or
set_location_assignment FPLL_1DB -to inst|xcvr_fpll_a10_0|fpll_inst
Besides, how many boards that you encounter this problem?
Regards -SK
Hi SK,
I've tried all 4 locations (1CT, 1CB, 1DT, and 1DB) of fpll, and verified that they were placed in the specified location using the chip planner after compiling. FPLL still doesn't output in any of the location, while IOPLL does.
I have a total of 3 boards, and have tried on 2 of them, and they behave the same way. IOPLL works, and FPLL doesn't.
I really appreciate all the help so far. Do you have other suggestions of what I can look into?
- jpang105 years ago
Hi SK,
My FPLL works after I disabled calibration using
set_global_assignment -name VERILOG_MACRO "ALTERA_XCVR_A10_DISABLE_RESET_CONNECTED_TO_CAL_BUSY=1"Would there be an issue if calibration is disabled? It appears that calibration was busy, holding my fpll in reset.
What could be some possible causes that calibration wasn't able to complete?
