MaHa1
1 year agoPCIe hard IP and SerDes Transceiver Configuration in Cyclone V GX with 6 transceivers
Dear Intel Community and Intel Employees, I need to place one PCIe Gen1 x1 hard IP block and 4 SerDes Transceiver Channels of an third party IP of an switch into a Cyclone V GX with 6 transceivers (...
Ash_R_Altera
1 year agoHi,
These issues could be due to the way you have split up your reconfiguration controller, where the minimum "granularity" is a triplet, or perhaps the channel placement is constrained because you are using CMU PLLs, which can only be placed in CH1 or CH4 of a 6-pack.
I believe that you should check the clock sharing and the data rates that you are targeting within a bank. Please check the PLL sharing guidelines: 1.5. PLL Sharing
