PCIe hard IP and SerDes Transceiver Configuration in Cyclone V GX with 6 transceivers
Thanks for contacting Intel. I'm assigned to support request.
I'll investigate on this case and get back to you soon once I have any finding.
Meanwhile can I check with you on:
- Quartus version you are using?
- Are you able to share your design or something with we can regenerate the same error?
Thanks for your patience.
Harsh M
- MaHa11 year ago
Dear Harshx,
1. We use: Quartus Prime 18.1.0 Build 625 - Standard Edition
2. I 'm not able share the Design, because of Encrypted Third Party IPs and company knowledge.
When I separated the channels into the other Triplet, I ran into another problem:
Error (14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 Channel PLL(s)).
In the Transceiver Manual I found the Note, that for Full-Duplex communication, the Tx-path needs a CMU PLL which are sourced from channel PLL 1 and 4 in Cyclone V GX.
The only setup where the fitter can place was by only using 2 out of 4 SerDes transceiver channels.
Chip-Planner 5CGXFC7C6U19I7:
So, currently 3 of 6 transceivers are used that the fitter can place the channels.
We need 2 additional SerDes transceiver channels for our design, this would be 5/6 transceivers.
→ Is there a Solution to use PCIe hard IP with more than 2 SerDes Transceivers?
kind regards,
Martin Haiden
