rMa1's avatar
rMa1
5 years ago
PCIe Hard core和SG-DMA整合
我的系统中现在使用的是hard PCIe,接口是 AVMM with DMA。系统想提高数据吞吐率,想使用PCIe AVMM Hard core接口和SG-DMA整合,请问有没有这样的测试用例可以参考?使用SG-DMA是否一定要开启NIOSII?
  • If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
  • SengKok_L_Intel's avatar
    SengKok_L_Intel
    Hi
    This is not necessary to have NIOS in the design, the DMA descriptor controller can use PCIe BAR to configure. The PCIe IP for Arria 10 or Stratix 10 comes with the embedded DMA. If this does not meet your requirement, then you have to build your DMA controller. And yes, you can use the SGDMA to build your custom DMA controller, but there is no example design available.
    Regards -SK
    SengKok_L_Intel
