PCIE example issues
- 5 years ago
Hi Pieter,
And yes, indeed, if you run the software test as in figure 12, then the application accepts traffic loadup to MAX.PAYLOAD. BUT NOT THE TESTBENCH / APPS in simulation!
Yes. As in my previous reply, the testbench provides simple method to do basic testing and this does not cover all the traffic profile stimuli. If user wants to simulate with what is not covered in the testbench, user has to modify the testbench based on their requirements.
So, i think i am on the edge of improving the testbench and APPS to payload = max.payload. My question: if i would share this code with you, would INTEL be willing to compensate me for this effort ? (i think INTEL does not deliver what it says it does as described in the manual)
I apologize for the miscommunication if there is any. The reason I asked if you are willing to share the modification earlier is because there are some hobbyists share information, what they have created or method to solve problems in this public forum. Please do not share if the content is confidential or non-public accessible.
Thanks for your understanding. Do let me know if you have any questions or concerns.
KhaiY
Hi Pieter,
I checked with the team, we have 10G ethernet example design standalone that can generate from the 10G MAC IP GUI, but we don’t have PCIe + 10G ethernet design, where the customer need to integrate by themselves.
You may find the steps to generate the example design here: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20162.pdf
KhaiY
Dear KhaiY,
As i told you, we already worked with hte example in UG-20162. I understand you don't have an example design with the two connected.
What i don't understand, is that you write in the manual for the PCIE example:
The UG-01145 document says (page 157): "It can only handle received read requests that are less than or equal to the currently set Maximum payload size option specified under PCI Express/PCI
Capabilities heading under the Device tab using the parameter editor. Many systems are capable of handling larger read requests that are then returned in multiple completions.
meanwhile, i managed to send 8 bytes, but is a hard struggle. In fact, i am disappointed that this testbench / example cannot handle anything else but those 4 bytes. I reluctantly seem to have to accept that INTEL is not intented to repair this shortcoming, although the manual says it does accept TLP until max payload. Regards Pieter
