PCIE example issues
- 5 years ago
Hi Pieter,
And yes, indeed, if you run the software test as in figure 12, then the application accepts traffic loadup to MAX.PAYLOAD. BUT NOT THE TESTBENCH / APPS in simulation!
Yes. As in my previous reply, the testbench provides simple method to do basic testing and this does not cover all the traffic profile stimuli. If user wants to simulate with what is not covered in the testbench, user has to modify the testbench based on their requirements.
So, i think i am on the edge of improving the testbench and APPS to payload = max.payload. My question: if i would share this code with you, would INTEL be willing to compensate me for this effort ? (i think INTEL does not deliver what it says it does as described in the manual)
I apologize for the miscommunication if there is any. The reason I asked if you are willing to share the modification earlier is because there are some hobbyists share information, what they have created or method to solve problems in this public forum. Please do not share if the content is confidential or non-public accessible.
Thanks for your understanding. Do let me know if you have any questions or concerns.
KhaiY
Hi Pieter,
I would like to inform you that I am still working on this. Please allow me some time on this.
KhaiY
Hi KhaiY, thanks for updating me. It is really not an easy part of code.
What i could not figure out, or not understand is: if you load the board with the example code, and connect it to the other PC, as described in document an-855 paragraph 1.7 Hardware Installation, does this also use the very same configuration? Because it says: ($1.8) Set the Transfer length to 100,000 bytes and the Sequence to Write only,....transfer data from the FPGA to the system memory in chunks of 100,000 bytes. So, you would expect the very same application (APPS and the others) really do accept and send back packets of length 512 / 1024 / 2048 packet to larger chunks... If so, then why not in the testbench?
(we have this software test working)
Looking forward to your progress / feedback
Regards, Pieter
