PCIE example issues
- 5 years ago
Hi Pieter,
And yes, indeed, if you run the software test as in figure 12, then the application accepts traffic loadup to MAX.PAYLOAD. BUT NOT THE TESTBENCH / APPS in simulation!
Yes. As in my previous reply, the testbench provides simple method to do basic testing and this does not cover all the traffic profile stimuli. If user wants to simulate with what is not covered in the testbench, user has to modify the testbench based on their requirements.
So, i think i am on the edge of improving the testbench and APPS to payload = max.payload. My question: if i would share this code with you, would INTEL be willing to compensate me for this effort ? (i think INTEL does not deliver what it says it does as described in the manual)
I apologize for the miscommunication if there is any. The reason I asked if you are willing to share the modification earlier is because there are some hobbyists share information, what they have created or method to solve problems in this public forum. Please do not share if the content is confidential or non-public accessible.
Thanks for your understanding. Do let me know if you have any questions or concerns.
KhaiY
Hi Pieter,
I find this reference design relevant to your request.
Cyclone 10 GX PCIe Gen2 x4 Avl-ST
https://fpgacloud.intel.com/devstore/platform/18.0.0/Pro/cyclone-10-gx-pcie-gen2-x4-avl-st/
If it's not , you may find some other design examples in Intel FPGA Design Store.
https://fpgacloud.intel.com/devstore/?page=4&search=pci
Do let me know if the above design is helpful.
KhaiY
Hi KhaiY,
Thanks for your response. Something in our communication seems not working.
the design example you suggest, is the one i am working with:
The design example i started with, and for which i ask your advice, is the one described in UG-01145_avst | 2020.06.02 (newer versions may exist), and which you can download from the IP Catalog in Quartus PCI Express / Intel Arria 10 / Cyclone 10 Hard IP for PCI Express => Platform Designer => Parameter setting: System Settings: Standalone, Avalon-ST, Gen2x4, 64 bit @ 250 MHz, Native Endpoint, Balanced, RX Buffer: Header: 112 Data: 440. All other settings: default. Example Design: PIO, Development Kit: Arria 10 GX Development Kit (I have the Cyclone 10GX development kit, and i understand this should not be a problem)
I asked you: is it possible to change the testbench and application, such that transfers with Payloads of many bytes is possible, the design example only allows for 4 Bytes. I changed the testbench, the TLP Parser such, that in my opinion it should transfer 8 Bytes, but so far no success. My assumption is: if I manage 8 Bytes, i can also change to many bytes, as long as within the boundaries of the maximum payload.
What i really want: connect INTEL's Low Latency MAC 10-GBASER design example to the hard IP PCIE of the PCIE example design as described above. Instead of finding out the wheel myself, an example design doing exactly this will be most appreciated. The list of design examples you send me, do not contain (unless i missed something, you can never exclude that) such an example.
So, I really hope somebody did this is exercise (connect LL MAC to PCIE) and is willing to share this code with me. Otherwise, I have to do it myself, and a step to achieve this, is to make the PCIE design example suitable for transfers >4 Bytes, for which i need your help.
I hope this clarifies my requests...
Regards, Pieter
