PCIE example issues
- 5 years ago
Hi Pieter,
And yes, indeed, if you run the software test as in figure 12, then the application accepts traffic loadup to MAX.PAYLOAD. BUT NOT THE TESTBENCH / APPS in simulation!
Yes. As in my previous reply, the testbench provides simple method to do basic testing and this does not cover all the traffic profile stimuli. If user wants to simulate with what is not covered in the testbench, user has to modify the testbench based on their requirements.
So, i think i am on the edge of improving the testbench and APPS to payload = max.payload. My question: if i would share this code with you, would INTEL be willing to compensate me for this effort ? (i think INTEL does not deliver what it says it does as described in the manual)
I apologize for the miscommunication if there is any. The reason I asked if you are willing to share the modification earlier is because there are some hobbyists share information, what they have created or method to solve problems in this public forum. Please do not share if the content is confidential or non-public accessible.
Thanks for your understanding. Do let me know if you have any questions or concerns.
KhaiY
Hi Pieter,
Please find attached.
KhaiY
- PVanL5 years ago
Now i see: in your folder customer/ip/pcie_id/ there is only a small subset of files. Even more strange, is that in my design those files do not exist at all!!!???
There should be the set of files as shown in the pci_202_mod/pcie_a10_hip_blabla/ip/pcie_ed/directory. My assumption was you would load the design example from INTEL website, and then replace the changed files with my files. (quartus 20.2) Apparantly the design example is not properly loaded into your machine, hence it will definitly not run.
The problem is: the fully compressed design is 0.7 GB (with 762 files), which does not fit in the drag & drop field below, so i cannot send this design to you, unless via a direct link to your email.
So, my suggestion is:
So, please install the full design from the INTEL website, and make sure it runs. I am afraid you loaded a different design, given those clock_in and reset_in files that do not exist in my design.
Then replace the files from INTEL example, with the files in the attachements, that i sent you earlier.
But maybe another appraoch example is also possible:
What i really want, is connect my ethernet PHY, via the INTEL Low Latency MAC, to the PCIE Hard IP (gen2 x 4) and map it onto the cyclone10GX development board.
(I have in the INTEL design example for Low Latency MAC, replaced the INTEL PHY iwth my own PHY, and it runs in simulation, and i still have difficulties in getting the tranceiver properly mapped onto hte cyclone10GX)
If you do have an example with this, (but then of course with the INTEL PHY), that would be most welcome!
Regards, Pieter
