LKrup
7 years agoPCIe device not detected after programming CVP peripheral core
I have Reflex Attila Arria 10 GX (chip is Engineering Sample) board with simple PCIe test project on which 'lspci' command shows Altera device. I proceed with instructions in ug_a10_cvp_prop.pdf and ...
Nathan_R_Intel
Contributor
7 years agoHi,
Noted that your JTAG issue could be related to ES silicon version. However, I also found that your attached design is not working.
I verified your cvp_test.qar is not working when ported over to Production device and tested in Arria 10 Development Kit. It cannot link up to LTSSM L0.
Hence, please use Quartus Generated Example design and try it on your board.
To generate the PCIe Example design, you can refer to the following user guide.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-a10-pcie-avmm.pdf
Alternatively, you could try with the reference designs available in Intel Wiki as well.
https://fpgawiki.intel.com/wiki/Reference_Design:_Gen3x8_AVMM_DMA_-_Arria_10
Nathan
